5.3 swap ECM question
I found another motor and trans with harness and ecm for $600 but the its got $150k on it and has a rough idle. He has video of it running before he pulled it.
Any guidance would be appreciated.
The second seller with motor and trans for $600 isnt quite sure he has a PCM or wire harness. Waiting for his confirmation yet.
So as long as its the same year truck, it will work correct?
The second seller says its an 05 motor and married trans with 150K on it. I was recently at a local junkyard and saw a 05 silverado with severe front end damage to it. But was thinking I may be able to get the wire harness and pcm if its located on the drivers side cab side. The passenger side was hit so hard that you can see the motor just looking at it. There isnt a fender left. Cant get the mileage on it though.
I also found a GMC Envoy V8 but the wire harness was cut. Looks like it can be spliced back together as both pieces are there but being a junkyard vehicle it looks like ppl were poking and prodding at it. Its missing some stuff. Again cant get any mileage off it though.
1 - full time 12 volt power to the memory keep alive wire inside the PCM
2 - ignition key hot power to actually power up the PCM - this is different than "1" immediately above.
3 - fuel pump power
4 - electric fans power if using e-fans to cool the radiator
Go to the LT1Swap.com web site for further guidance.
Rick
