69 Camaro front steer
Old Jul 17, 2018 | 01:54 PM
cookseyb's Avatar
Default 69 Camaro front steer
Can I replace the stock steering box and linkage from my Camaro with a 1973 Nova so I can get front steering and make the LS1 oil pan work better? Thanks
Old Jul 17, 2018 | 02:01 PM
-TheBandit-'s Avatar
The '73 Nova has the same suspension and rear-steer arrangement as your 69 Camaro - in fact the '67-69 Camaro and '68-'74 Nova use the same subframe and interchangeable steering / suspension components. There is no practical way change to a front-steer arrangement in this frame nor is it needed to swap an LS engine into the car. There are several aftermarket pans that will get you the fitment you need or if you are on a very tight budget you can modify a factory oil pan.
Old Jul 17, 2018 | 02:57 PM
cookseyb's Avatar
Thanks, I thought they were different . Thanks for your answer.
