LS Fox body project
I'm in the process of transplanting an LS2 in my SVO, and have a Maximum Motorsport MMK-1 K member. For fitment I bought the Holley 302-3 oil pan, the Hooker/Holley LT headers, and modded some SN-9/LS swap motor mounts. Since then, Holley has introduced their own mounts as part of their package. I believe that their combo will also work with a stock Ford K.
Here is a post from a Holley R&D guy who uses the screen name "Toddoky" . https://ls1tech.com/forums/conversio...ew-thread.html Lots of good info and pics there.
I was hoping to find someone that was doing the same thing I'm planning so you're definitely a blessing. It's all about synergy! Check out what I was talking about concerning the SVO rear in this link.
Seriously, I consider having the ear of a former circuit racer a privilige but I'm not a complete dumbass. Passenger side battery in the back should be de-riguer for anyone seeking track time so that's good advice but how do you land on the PHB vs. Watts debate? Are sway bars the only things you use to tune your handling? I'm planning on making similar power with a car that weighs about as much, is a sticky 225/50-16 enough tire? Is the Trak-Loc rear a clutch type limited slip or something different? Wouldn't a torsen T2 be superior?
@Toddoky
Thanks for the heads up. I'll be studying up on these offerings and will be sure to have more questions. It never ends does it.
If I can answer any swap questions for you, let me know.
Mine’s adjustable perches, Eibach springs, Koni Sports, roll center correctors up front, cast/camb plates, strut tower bar, reinforced rear lower arms, adjustable Panhard and adj upper torque arms, poly bushes everywhere and 28mm/22mm bars. Stock rear discs; 12" rotors off of a C70 Volvo coupe and billet aluminum calipers from Wilwood. Don't forget -- none of this does much of anything unless two critically important things are addressed properly. One is tires (with appropriately sized wheels -- as light a combo as you can afford) and the second is tightening the nut behind the wheel. If you haven't been to a few driving schools and raced a bit --- then the car (even stock) will be WAY more competent than you are.
From the following snippet:
brakes are 10.5" 5 lug vented rotors
gearing is normally 3.27 or 3.08
SVO and 87-93 Saleen shared these axle shafts.
+1. I would have said that if you hadn't said it first. I don't get the reference, what does Burbank/Laugh-In have to do with that car?
@Michael Yount
Noted, even the aluminum blocks come in at 478lbs. complete. Beautiful work! Who needs an M5 when you have that ride
The chin spoiler up front makes the look of your car, how do I get one? All the notches I've seen come with a 7.5" ring, why add the install headache and ~40lbs. of an 8.8"? I was planning on an LC9 and a snail for my build, did you use the stock mount or get an aftermarket "K-member" to seat it? I have so many additional questions but I don't want to overwhelm you in one post.
@Stampede4ever
Thanks. Just to clarify, are you saying ALL 28 splines will fit ANY manufacturer ring gear differential, including torsens or that Ford 7.5" and 8.8" house the same axles? Has anyone done a compatilbilty list of axles and rears? I think I want a T2-R diff on my build but only if it isn't too much trouble.
Stampede.
LOL, I remember that!
@Michael Yount
Can your PHB pivot from either side of the axle (reversible mount)? I've rented track time intermmitantly three times a year for most of my adult life and I know the basics of body dynamics. In most cases, any stock Fox or LX would be a bottleneck for me. I haven't driven the SVO but I've been told the sloppy rear and body flex on that car will also limit my time around a track. I know the unsprung weight and tire patch are inseparable from the other suspension decisions but would that prevent you from giving us a general impression of how much tire would be enough for ~400whp and ~3200lbs. GVWR?
@rtagg
Thanks for the link above, I've been studying intently even though there are too many "are we there yet" posts in that thread, LOL. Is your project complete? I noted your impatience and didn't yet see your conclusion.
As I said - contact the folks at Maximum Motorsports and begin your discussion about suspension and dynamics there. You can get plenty of tire under the front and back of a fox body for what you're talking about. I think I mentioned sub-frame connectors earlier - they are a must. Even better would be a cage -- but I never recommend one in a street car. Too easy to hit an un-helmeted head on one. You can set the fox body up to handle quite well.
Thanks for your input. It will be a street car too so no roll cage, just underframe support. I think you've understood me, a reversible mount would have symmetrical mountings so the PHB can be optimized for any road course (biased for right or left turning). The MM PHB is NOT reversible because its design would interfere with the exhaust if mounted the 'wrong' way. As I understand it, the PHB will have a different roll center on left and right turns as it raises and lowers the rear. Does your experience corroborate this understanding? Why would two additional mounts take up a bunch of real estate, is there any more to it than that? Sub-Frame connectors are on my list, do you think the longer ones are worth the extra cost and weight? Yes, the fox wheel wells can fit 255's and 8" wheels without fender flares but why add roll resistance and unsprung weight if you can avoid it? That's why I asked your opinion on the adequacy of VR 225/50-16's for an 8lb/hp car weighing ~3300lbs.
@rtagg
I saw the link where you sold off your headers and mounts so I'll assume you got your complete now. A truck LS has taller heads than those in the F and Y body cars, if you used a truck motor, did you have any hood clearance issues?
I can't answer your question about how much tire is enough. How hard do you want it to corner? That will direct you towards your tire size choice. Compound equally, if not more, important. If you have a suspension and unibody cable of really planting the tire, you can get an awful lot of cornering force out of sticky 225's on 3300 lbs. My gut tells me you'll want 245-255 on 9-10" wheels.
Late add - my Cayman S was capable of right at 1G with 235/265 sport Pilots. About 3k lbs
A great answer satisfies a question and that was exemplary. Thanks. The Watts solves the problem (if it really is one) of the 0.25" sagitta but it shares the same change in roll center of the PHB unless you mount it below the axle which is too low for street. I just discovered the Grand Marquis and Crown Vic of that era had a Watts ahead of the axle. I wonder if that unit will fit a fox? (Hey, @rtagg, any info on this?
) I was planning on weekend racing club events and possibly some SVRA so if I can get an edge with a reversible PHB, why not look for one with that feature? Those were great numbers on the Cayman, did you use the same width wheels front and rear even though the tires were wider in the back? I guess a wider wheel will minimize the sidewall deflection on hard cornering but I've been reading more and more people saying they have gotten use to that 'squishiness' and they say a tire that stands slightly proud breaks more controllably. Has your experience been different?@rtagg
I sent an email to MM to ask about the clearance with a stock hood and truck intake and will report what they say. When you pulled out your SVO, did you happen to notice how much space was under the intercooler? Was there enough to mount a duct?
Vic/Marquis info seems wrong to me; can’t imagine why Ford would go Watts on the land barges when they wouldn’t even go Panhard on the Stang; how would you even use a Watts in front of a solid axke?
Edit - had to look it up -- memory failed me (old = happens all the time) ; 2010 Cayman S -- frt 235/40/18 on 8" wheel; rear - 265/35/18 on 9" wheel.
