Oil Dip Stick = FLEXIBLE and Turbo
Old Jul 27, 2018 | 04:19 PM
epfatboy's Avatar
Default Oil Dip Stick = FLEXIBLE and Turbo
Got a great deal on a Flexible oil dip stick, unfortunately it is roughly a 7/16" OD tube and my block (2005 4.8 from a Express 2500 van) requires roughly a 3/8" diameter tube.
I have flipped the truck manifold and was planning to bolt the support bracket for the handle to a tab on the exhaust manifold.
Anybody got a link to a oil dip stick (flexible) that will work for my block?
Old Jul 27, 2018 | 07:48 PM
How about brazing/welding a short piece of 3/8" tubing to the 7/8" ? That is IF the dipstick will still fit thru the 3/8"...….
Old Jul 28, 2018 | 05:29 AM
epfatboy's Avatar
I think the stick will fit, I have the stock dip stick and can cut the end off. Wondering if an epoxy would work here too.
Is the dip stick I have for an oil pan access hole?
Old Jul 29, 2018 | 02:44 PM
epfatboy's Avatar
Thanks for the idea G!
This is what I landed with.
I cut about 1" past the o-ring and collar off the orig tube
https://photos.app.goo.gl/R38XwdqaTKpz9imj7
I was able to remove the tube from the coupling on the new stick
Then I drilled out the coupling so that I could press the old tube into the coupling
https://photos.app.goo.gl/omHDVA5LfuxvZP9L9
Before I pressed the old tube in a wiped it down with a little JB Weld
https://photos.app.goo.gl/gxCvejhmkRKNeKP28
** No way I needed JB here as the press fit was tight but I had it laying around and never use it so why not.
Quick test fit has the stick hitting the oil so it is long enough. Just need to weld a mounting tab to the exhaust mani and I'll have myself a locking flexible dip stick that is totally out of the way.
Old Jul 29, 2018 | 03:07 PM
Good to hear, man! Good ol' JBWeld…. better to use it and not need it, than to need it...…….. well you know the rest...lol
