4l60e lq4 swap
Old Jul 30, 2018 | 11:37 PM
ahmad almtere's Avatar
Default 4l60e lq4 swap
i need info for my swap i have 4l60e 96 from caprice will it work with 2000 lq4 harness with out modification
my tranny is 1 piece case
Old Jul 31, 2018 | 01:10 AM
PeteS160's Avatar
LQ4 most likely had a 4l80E behind it so you will have to do some repining in your harness. Once that's taken care of it will plug into your 4l60 and shift it just fine(assuming pcm is setup for the 60) but you'll be missing a bell housing bolt top center and you may have inspection shield fitment issues.
Just be aware that a 60 won't do well behind the LQ4, if you stand in it WOT between shifts your going to kill it pretty quick.
Old Jul 31, 2018 | 07:28 AM
thanks do you have link or
Diagram for the repining the harness
thanks again
Old Jul 31, 2018 | 11:20 AM
PeteS160's Avatar
thanks again
This link is to make a 4l60 harness into an 80, if you follow it in reverse it will guide you into making your harness into a 60E version.
http://www.lt1swap.com/4l60e_4l80e_harness.htm
Old Aug 1, 2018 | 06:34 AM
Thanks
Old Aug 2, 2018 | 12:02 PM
hokeplaya05's Avatar
FWIW you'd be way better off finding a 4l80e to go behind the lq4, won't have to mess with the harness and you'll end up doing the swap down the road anyways when you keep blowing the 60e's up.
I blew up the 4l60e in my truck which is a stock small block 350......
