5.3 harness rewire
Old Sep 28, 2018 | 07:26 PM
  #61
Bapeon4s's Avatar
Originally Posted by Kawabuggy
RED 76 LT. GREEN/WHITE IAC COIL B HIGH
RED 77 LT. GREEN/BLACK IAC COIL B LOW
RED 78 LT. BLUE/BLACK IAC COIL A LOW
RED 79 LT. BLUE/WHITE IAC COIL A HIGH
https://www.google.com/search?q=GM+I...fidLtGdA4rbwM:
Look at link above for picture of where each wire goes.
Old Sep 28, 2018 | 07:28 PM
  #62
Bapeon4s's Avatar
Got it everything is soldered & extended I decided to remove all the 4l60e wiring also If I do switch trans I’m doing a Th400. I will finish up with the fuse block tomorrow !
Old Sep 28, 2018 | 07:31 PM
  #63
Bapeon4s's Avatar
Ready for loom 🙂
Old Sep 30, 2018 | 02:57 PM
  #64
Kawabuggy's Avatar
Waiting on the video of it running!
Old Sep 30, 2018 | 02:59 PM
  #65
Bapeon4s's Avatar
I’m on it chief 😎
Old Oct 4, 2018 | 04:50 PM
  #66
Bapeon4s's Avatar
The relays for my harness arrived today following lt1swap parts list but they are 40 amp instead of 30 amp relays. Should I exchange them or should I be fine running 40 amp?
Old Oct 4, 2018 | 08:56 PM
  #67
40 amp is the capacity. I wouldn't worry about it.
Old Oct 4, 2018 | 08:59 PM
  #68
Bapeon4s's Avatar
Perfect thanks I appreciate the help !
Old Oct 4, 2018 | 09:15 PM
  #69
Alex_olds's Avatar
Originally Posted by rubrhammer
If you have a printer and can print from email send me your email address and I'll send you schematics for the LS1 harness.
Hello,
Do you still have the schematics? I have a factory harness that I would like to rework.
Old Oct 10, 2018 | 07:58 PM
  #70
Bapeon4s's Avatar
Originally Posted by Alex_olds
Hello,
http://lt1swap.com/2000corvettepcmpinouts.pdf
Old Oct 10, 2018 | 08:07 PM
  #71
Bapeon4s's Avatar
Fuse block & relays are ready wired in my obd2 port also so I can hopefully run gauges on iPad while I buy some nice ones, I’m leaving the wires in the harness ready to wire into gauges. I found out the “Dorman” fuse block that lt1swap shows is REALLY cheap quality. I went down to autozone & got me a 5 fuse version they sell. Has lid to protect fuses & it uses plugs instead of direct solder to fuse holder.
Mil wire for check engine light & the ignition/12+ wires from pcm also need a bit of help figuring out other than that I’m ready to drop in this baby 4.8 !!!
Old Oct 10, 2018 | 08:17 PM
  #72
Bapeon4s's Avatar
