1995 4l60e
Old Aug 27, 2018 | 02:31 PM
allenturnel's Avatar
Default 1995 4l60e
I put a 1994 4l60e in a 95 z28 switched valve body will that work
or do I have figure out how to get torque converter lock up
Old Aug 27, 2018 | 07:48 PM
Kawabuggy's Avatar
Okay... 1995 was a 1 year only transmission. If you used a 1994 trans, just swapping the valve body WILL NOT WORK. The reason is that the PUMP is different between the two transmissions. The '95 uses a PWM pump (different internal passages in the pump and different TCC valve). The '94 is a NON-PWM pump (just like it's predecessor the 700R4).
To make the 1994 trans work in a 1995 vehicle you will need to swap the following parts-ALL from a '95 trans-pump, valve body, separator plate, internal wiring harness. Is there a reason you can't find a 1995 unit??????
