04 lexus ls430 swap with an LS engine
Old Sep 21, 2018 | 01:29 AM
Bsavage's Avatar
Default 04 lexus ls430 swap with an LS engine
I was wondering how to wire up the Ls engine and keep the functions of my car? Do i need to get a new ecu or can i wire the gm ecu to the Lexus ecu?
Old Sep 21, 2018 | 04:07 AM
8.Lug's Avatar
You need to ask this on a Toyota/Lexus forum.
Old Sep 21, 2018 | 06:27 AM
Michael Yount's Avatar
The vast majority of folks will use either a GM ecu or an aftermarket unit (MS, Holley, AEM, etc.) ecu to run the LS engine and (usually) an automatic transmission that needs controlling as well. As 8.Lug alluded to - then you'll likely need the assistance of folks who've swapped similar Lexus vehicles to figure out what part of the Lexus 'stuff' you need to keep in order to have all the rest of the car's non-engine related systems to work. The newer the vehicle, the tougher it is as more and more of the functions for things like door locks and power windows are controlled by a computer somewhere that usually at least "talks" to the OEM ecu.
Old Sep 21, 2018 | 11:27 AM
Bsavage's Avatar
I appreciate your response thank you
