LS Swap Fuel System Discussions
First system is the return fuel system.
Tank-> PreFilter-> Pump-> PostFilter-> Rails -> RegulatorValve -> Tank.
The parts will be used are below:
1. Fuel filter 100 microns (Brand: FiTech / Part#: 80111)
2. Inline high pressure fuel pump 255 lph (Brand: FiTech / Part#: 50101)
3. Fuel filter 30 microns (Brand: FiTech / Part#: 80113)
4. Fuel rail EFI (Brand: Holley / Part#: 850013)
5. Pressure Regulator Valve for EFI 35-75 psi (Brand:FiTech / Part#: 44020)
Second system I will call it semi-returnless fuel system.
Tank-> PreFilter-> Pump-> PostFilter-> RegulatorValve(2output)-> 1.Rails.2.tank
4. C5 1999 Pressure Regulator Valve
5. Stock L99 fuel rails
General questions:
A. What are the cons and pros for each system?
B. Should I use AN6 or AN8? And why?
C. Should I install the fuel rails in parallel or series?
Return fuel system questions:
A. There is Pressure Regulator Valves comes with vacuum line like the one upside. Do I need that vacuum line to be connected to intake intake manifold? what is the required pressure?
B. According to what I have seen. They are plugging the output of the Pressure Regulator Valve. Is that right? Or is there a valve that is coming with only one inlet and return line?
Semi-returnless fuel system questions:
A.Do I need to install a Fuel Pulse Damper?
