New LS480 Starts-Dies
Do you know if the spark to the plugs is being cut by the ecm to cause this or if it continues to be present during the die event until it stops, ...........Can Verify with timing light flash ...
With these two things you can understand what may be causing the issue and make it easier to troubleshoot. You will be able to determine if it is dying due to a tuneup issue that is wrong or or if something else is shutting it down. If fuel and spark continue and it still dyes then that is at least something you can rule out.
