Ls swapped S10
Old Sep 29, 2018 | 07:52 PM
Marc45167's Avatar
Default Ls swapped S10
Bought this truck unfinished has the 09354896 pcm and Current Performance harness, I'm not finding a MAF connector anyone have a schematic of the pcm pins.thanks
Old Oct 1, 2018 | 08:29 AM
1964SS's Avatar
http://lt1swap.com/wiringharness.htm should have the pinouts you are looking for. Your harness may have been built for speed density tune which would eliminate the maf.
Old Oct 1, 2018 | 02:44 PM
Marc45167's Avatar
Thanks for the very helpful information 1964ss I watched a video about the speed density tune so my next question is, is there a certain map sensor I should be using in accordance with the pcm and that harness?
Old Oct 1, 2018 | 03:00 PM
Dimeomboost's Avatar
Not sure which one u need. On my s10 I I use no maf. A gm 3 bar map and I separated the iat sensor wires and wired the iat separate into my charge pipe the pinouts are easy to follow
Old Oct 1, 2018 | 04:34 PM
Marc45167's Avatar
  1. This harness has the iat connector,but there is no intake hose system on it yet been looking for a setup,not sure which type or brand that be best if you can help me here also this be great I really appreciate it thanks in advance
Old Oct 2, 2018 | 06:58 PM
rpturbo's Avatar
On a s10, there are so many different configurations, there is no 1 way. Is the radiator stock, or something from a different car or aftermarket? Where are the top/bottom hoses at? On mine, I just ordered from intake hoses, and configured a setup that works nicely. I made a heat shield from some sheet aluminum.
