lsx swap
Old Oct 1, 2018 | 06:05 PM
kbhome's Avatar
Default lsx swap
I am swapping a 2006 l33 into an rx7. My question is can I put a lm7 back into the truck without a mess.? Will there be an issue with the harness.?
Old Oct 1, 2018 | 06:18 PM
Should bolt right in, and everything connect. Might have to retune for the different cam even though it's not much different.
Old Oct 2, 2018 | 12:59 PM
408gto's Avatar
Atsma is right it’s the same and the cam isn’t big enough to make a difference in the tune but make sure you reuse or pick up another dbw throttle body depending on the year of lm7 99-02 was dbc unless they had traction control and 03 up all was dbw if you didn’t know
