Need advice on Powersteering pump
Old Oct 11, 2018 | 11:53 AM
Fox5.3's Avatar
Default Need advice on Powersteering pump
I have a 5.3 that is going in a 88 mustang that is mostly complete. Im just mocking everything up before so i know it fits and i ran into the problem that my ps pump lines are hitting my turbo manifold. I am using the stock ps pump and alternator using lssimple brackets. Here is a picture of my accessory drive and where the lines hit. I am wondering if anyone knows of a pump with the same mounting holes or a way to move those line out of the way. (Truck PS pump)
Heres a link to the pics. https://imgur.com/a/Op29KJM
Old Oct 11, 2018 | 02:45 PM
chevalierss's Avatar
you can replace those lines with -an fittings adapters, screw them right in to the back of the pump and make a set of custom -an hoses to route where you need
Old Oct 17, 2018 | 10:43 AM
Fox5.3's Avatar
This is my pump, it only has one screw in for an am fitting. What pump would work, can someone recommend one that would replace the truck one
Old Oct 17, 2018 | 02:49 PM
Fox5.3's Avatar
My ps pump only has one fitting that I can unscrew and the other is permanent. Does anyone a pump that keeps the same truck style but with an fittings for the back?
Old Oct 17, 2018 | 02:51 PM
Fox5.3's Avatar
my pump only has one fitting that actually unscrews the other is a metal line coming out of the pump itself. Does anyone know of a pump that keeps the same truck style but with the ability for an lines in the back?
Old Oct 17, 2018 | 03:09 PM
The metal line is the return, which carries NO pressure. Slip a hose over it and clamp it.
