Ls2 t56- stand alone harness
Old Oct 15, 2018 | 05:58 AM
94supercam's Avatar
Default Ls2 t56- stand alone harness
im in the middle of cutting down my wiring harness an making it a stand alone. Motor is out of a 06 gto with a e40 ecu. My main question is on the c1 plug on the ecu you have pin 10 which is a brown wire. It says it goes to engine control relay coil. Does this wire need power or to be grounded??? Or do I even need it at all?
thanks
