Power Enrichment
Old Nov 6, 2018 | 12:35 AM
Kevin Fodge Jr.'s Avatar
Default Power Enrichment
I apologize if this has been asked before, I searched and didn't find anything super relevant. I'm trying to get power enrichment to come on at a decent time, what should I do with the map setting. It's currently at 55kpa to enable. Can I set that to 0 and be okay?
Old Nov 6, 2018 | 01:03 AM
truckdoug's Avatar
55kPa is like idle vacuum, thats probably fine. just make sure there's no rpm disable or delay in seconds. should be all on the PE page under the fuel tab.
Old Nov 9, 2018 | 04:13 PM
rpturbo's Avatar
I have mine at 55kpa, and the rpm at 2500, so it will not enable until both of those are met. You can adjust those as you want to make it come on when you want it to. You would get more replies if this were in the tuning section.
