E40 LS2 harness connector questions
I assume white is for the fuse block, and guessing black connected to the body harness?
I have a pinout for the E40, trying to figure out everything I can remove/keep. I've got a good bit done, but there's also a handful of pins I'm not sure about.
For the 2 connectors pictured in my og post, I shouldn't need to keep anything from the black body harness connector right?
The fuse connector, I'll obviously just take the wires I'll be using from it and add to my own fuse block.
So I should just be able to run those wires ( app, mil, tcc) from the PCM pins directly to the source, ie the pedal, sensor, ECT right?
I'm new to this stand-alone wiring stuff and feel a bit over my head. Can wrench on a car and build an engine all day but lost on this. Lol
