Old ground strap: What is it? Can I fix it?
Old Nov 19, 2018 | 09:06 PM
Vetteman61's Avatar
Default Old ground strap: What is it? Can I fix it?
Hello all,
My 1978 Caprice had a ground strap that came from inside the HVAC box and went in through the heater hoses. The strap has been broken. I'm not familiar with this and I'm not sure where it goes or what it grounded. I'm also not sure if it went to the body or the engine. Since it's inside the box I can't follow it. Would it be possible for me to solder a regular wire on the end of this strap and connect it to a ground? I'm not sure how to fix a broken strap.
Thanks,
Brandon
Old Nov 19, 2018 | 09:10 PM
A ground is a ground. I think if you attach another wire to it and connect it to the body or chassis it should be fine.
Old Nov 21, 2018 | 02:42 PM
Old Geezer's Avatar
Look around on the firewall. The missing end may be on a screw. You can fold the woven cable up, and crimp it in a loop connector.
Old Nov 21, 2018 | 04:12 PM
pdsq98gt's Avatar
It looks like a heater core ground to keep stray voltage in the coolant from arcing to ground causing heater core leaks. You don’t see it to often but it exists. Just crimp an eyelet on the wire and connect it to ground.
Old Nov 22, 2018 | 12:59 PM
Vetteman61's Avatar
That's interesting, I'd never heard of a heater core ground. Crimp an eyelet on it, of course! That seems like the obvious solution but I wouldn't have thought of that on my own. Thanks!!
Old Nov 23, 2018 | 03:43 PM
TPIZ92's Avatar
Auto parts stores sell them complete as well, usually in 12 or 24 inches with eye lids on both ends fyi. Some can be found in the help section as well.
Old Nov 23, 2018 | 04:01 PM
gMAG's Avatar
The ground is probably there to equalize electrical potential & to contain corrosion between dissimilar metals/heater core/copper/brass, & steel,as coolant fluid passes through it.
