Gearing in turbo a-body
Old Nov 21, 2018 | 06:59 PM
dewchugr's Avatar
Default Gearing in turbo a-body
Trying to decide what would be the best gears for an a-body 5.3 turbo, ss2 cam, 4L80, tires not sure, probably 18-19" around 29.5". Strictly a street machine. I was thinking either 3.42 or 3.73.
Old Nov 21, 2018 | 07:28 PM
truckdoug's Avatar
What weight, converter and turbo?
Honestly anything over 550 wheel will be near impossible to hook on the street with a small sidewall tire
Old Nov 22, 2018 | 07:52 AM
PhilistineAu's Avatar
Yes. The answer to your question is yes.
Final decider: how much of your time is spent on a highway / interstate? If the answer to that question is anything more than "a fair bit" i.e. "a lot", "i drive to work on one", "pretty often", you get the 3.42. Otherwise, you can get the 3.73.
Don't overthink this too much - you going to be able to light up the tires with either and the two ratios you mention are the most common sweet spot up for discussion. I wouldn't go a higher or lower ratio than the two you mentioned, but neither is a bad decision - you are right on the money... Unlike my 1985 C10 with something like a 2.73. That's a bad ratio to go back with when you add an extra gear to your autobox.
Old Nov 22, 2018 | 08:25 PM
dewchugr's Avatar
Weight 3500ish. Turbo gt45 is what I have right now. Convertor, no idea. Street vs highway percentage I don't know. A lot of around town and some road trips, possibly 1000 mile or more.
I think ill go with the 3.42 for a bit better mileage.
Thanks
