First Gen Camaro Swaps
Looking for a change, I ended up buying Holley's Mid Mount setup. I found someone who wanted my old setup so it made the purchase easier. I read about the new alternator design and using a C7 water pump (cartidge type). After installation, the results blew me away. The biggest advantage I see initially is the alterantor output. This new style (similiar to a Mech Man) has on output of around (info I found through Holley) of 100 amps at idle. On startup, voltage is at 14.3v and I started driving it. with everything going (AC, both fans Ect) at idle voltage is still at 14.0v. I see this being an advantage in helping the electrical system, I don't think your cars electrical system is design to run below battery voltage ;-).
Not saying everyone has to go with the Mid Mount even though I love its compact design, I would definitely recommend upgrading to their new alternator if you are having charging issues. Also, make sure your charging wiring is up to speed also (proper size). It has the same bolt spacing as the camaro/truck LS alternators. Looking good and excellent performance is a win/win in my book.
https://www.holley.com/products/ls_p...BoC5CIQAvD_BwE
i am am running the version with the ATI balancer. Not sure if it is absolutely necessary but a nice piece in the end.
