evaporator core fitting stripped
Old Dec 22, 2018 | 08:45 PM
Vetteman61's Avatar
Default evaporator core fitting stripped
Hello all,
I was attempting to install a new accumulator and ended up stripping the threads on the evaporator core fitting. Is there any way to get a new brass fitting on there or am I going to have to get a new accumulator?
Thanks,
Old Dec 22, 2018 | 08:51 PM
ls1nova71's Avatar
There's no way to change the fitting, so you most likley will need a new evaporator.
Old Dec 22, 2018 | 08:56 PM
Vetteman61's Avatar
Super lame. Thanks for the response.
Old Dec 22, 2018 | 09:33 PM
Michael Yount's Avatar
Rock Auto -- GPD 4711337 Core Size (IN) millimeters: 255 x 345 x 92 $61
Old Dec 22, 2018 | 09:46 PM
fbrown540's Avatar
I noticed that use are using a later model caprice condenser. The later models changed to metric fittings. If you used a later model accumulator, it would have metric sized fittings. Maybe close enough to screw in and strip.
