Back up lights for a 6L90
Old Dec 25, 2018 | 04:26 AM
Boy Scout's Avatar
Default Back up lights for a 6L90
finished my swap getting a 2010 5.3 with a 6 speed into my Toyota Land Cruiser. Been driving it as mush as I can while I keep connecting the small things.
How is is the best way to get 12v to the Toyota back up lights ? Is there a sensor and plug, somewhere on the 6L80 tranny ?
Old Dec 25, 2018 | 03:51 PM
350SS's Avatar
what are you using to select the gear? maybe it would be easier to put something there...i'm not sure there's anything on the trans that would do the job
Old Dec 25, 2018 | 09:29 PM
Boy Scout's Avatar
im just using the OEM floor shifter. Seems I’ve heard of folks using “micro switches”, to get the dash PRND12 indicator display , not sue what a “micro switches” are, but decided I didn’t need the dash display anyway. But maybe some kind of sensor on the floor shifter is needed for BU lights anyway
Old Dec 26, 2018 | 02:53 AM
pdxmotorhead's Avatar
Use a reed switch and a relay ,,, All you need is a magnet on the linkage and a small bracket for the reed switch.
The reverse switch is usually somewhere in the shifter mechanism on a stock chevy. (Floor or column).
Old Jan 17, 2019 | 11:29 AM
slowman's Avatar
Speartech has a solution for this.
http://www.speartech.com/product_p/6...lightrelay.htm
Old Jan 18, 2019 | 08:36 AM
bbtech's Avatar
I am doing a similar swap (2013 5.3, 6L80) and was wondering what you are using to know what gear the trans is using.
and have you set up tap shift?
butch
Old Jan 18, 2019 | 09:16 AM
slowman's Avatar
butch
We are using the CAN data stream to sense what gear the transmission is in.
Yes, we have done tap shift programming and had tap shift products available for swap vehicles since the 6L80 transmission came out.
