Compatibility Tac Modeule PCM
Old Dec 25, 2018 | 05:40 PM
Vetteman61's Avatar
Default Compatibility Tac Modeule PCM
Hello all,
I just started up my swap and the pedal has no response. From what I have found the components I'm using should all be compatible, but I'll run it by the forum to see if anyone has a different opinion.
Engine/Engine Harness/Trans/Pedal/TAC/Tac Harness - All from the same 2004 Avalanche
PCM - 2004 Chevy Express with a 4.8
Tune - 2004 Tahoe
Pedal sensor 1 is reading correct ohms. TAC is sending 5v positive and 5v ground as it should.
Thanks,
Brandon
