LS Oil Pan Mod / S10
Old Jan 25, 2019 | 08:17 PM
EZA's Avatar
EZA
Default LS Oil Pan Mod / S10
Anyone modified a stock LS oil pan to fit an S10, specifically a sec. gen. 4wd?
Old Jan 25, 2019 | 09:05 PM
Dimeomboost's Avatar
Yea it's been done by a few of us google awd turbo s10 the awd build thread shows how to clear the 4x4 front section
Old Jan 25, 2019 | 09:56 PM
jmd's Avatar
jmd
I think this is the thread ^ talked about.
https://ls1tech.com/forums/conversio...ld-thread.html
If you are going to lower the front diff (as some lift kits do,) do that before you mock up the shortblock with (truck) pan.
Old Jan 26, 2019 | 03:31 AM
tfi racing's Avatar
Still surprising that nobody has mass produced an oil pan for this swap, maybe Holley should take a poke at it...
Old Jan 26, 2019 | 06:46 AM
user 4737373's Avatar
We’ve yet to tackle the 4wd S10/Blazer LS swap, so I’m clueless as to what the design space for that application looks like. The Holley oil pans are designed during, and as part of, our swap system development efforts, so if a new pan is needed for this application it would happen at that time.
Old Jan 26, 2019 | 10:34 AM
EZA's Avatar
EZA
Thanks, guys. Mildon and Canton make a swap pan for the S10 4wd. Starts at $300 and goes up if you buy the add-ons. I had much rather use the stock alum. pan but was hoping to find some that had already done it with a set of measurements. I don't want a lot of down-time on my swap but don't mind saving money where I can. I have a 2003 S10 crew cab 4wd LS which is lower than the ZR and I don't want to raise it.
Old Jan 26, 2019 | 11:34 AM
jmd's Avatar
jmd
An AWD Sy/Ty has a lower ride height, but mounts the diff. the same place; lowering the diff. without lifting an S/T truck shouldn't present problems with shaft angles.
As to how much you need to drop it to clear the pan, please let us know.
