GM DBW pedal for SN95
Old Jan 30, 2019 | 06:29 PM
V8EATR's Avatar
Default GM DBW pedal for SN95
I'm looking to do an E38 PCM in my Gen 4 5.3 swapped SN95. It seems I need a GM DBW pedal to make it work, does anyone know of any brackets or a how to for this? Thanks.
Old Feb 1, 2019 | 07:39 AM
79LS1FOX's Avatar
I had to make my own which was just an aluminum plate that I bolted to the pedal unit and drilled for the stock Mustang mounting studs, thats the easy part, then you have to cut and reweld the pedal arm because none of them fit a mustang floor or tunnel, I used one from a 2007 Corvette. Good luck.
Old Feb 1, 2019 | 08:18 AM
Michael Yount's Avatar
Not in a Stang -- but E38 PCM out of an 08 Corvette, so I used a C6 Corvette pedal to assure compatibility. I'd get the pedal -- and then see what you have to do to mount it where you want it. I took some careful measurements before I removed my OEM pedal (cable) because the pedals in mine were perfectly spaced for heel/toe action with the manual trans. I cut off most of the Corvette arm/plastic pedal and bolted/welded on my OEM Volvo assembly. Then was able to mount the DBW assembly to the firewall such that the pedal ended up exactly were it was before. Looks completely stock unless/until you get way up under the dash to see what the Volvo pedal is attached to.
In short -- you'll have to fab this the way you want it to be.
Attachment 714045
Attachment 715577
