Abs inop
Old Feb 18, 2019 | 03:30 PM
Dub Wair's Avatar
Default Abs inop
After completing my LS swap into my 94 z28 my rear brakes are not engaging. So I basically on have front brakes even after brakes being bleed (not sure if they done it correctly) new pads new roders and master cylinder. Also E brake for rear not working either. Any suggestions?
Old Feb 22, 2019 | 01:17 PM
Muadi's Avatar
Not sure how to answer. You did an engine swap and added a new master. Is there a chance that there is any damage to the brake tubes? Are the brake tubes correct for front/rear? Was there anything done to the ABS unit? For the parking brake, they systems are separate. When you activate the parking brake, is the cable moving? Was it damaged or re-hooked up after the engine was replaced? (just wondering if the transmission was removed or replaced, possibly damaging something in the transmission tunnel)
Old Feb 22, 2019 | 06:07 PM
Dub Wair's Avatar
No rear end work was done or removed. I know for fact I bent the front brake line tubing but no creases. As far as trans tunnel I dont think so because the engine was removed from bottom.
Old Feb 22, 2019 | 06:16 PM
LLLosingit's Avatar
Are you getting good pressure while bleeding at the rear? You could have air trapped in the line.
Old Feb 22, 2019 | 06:20 PM
01CamaroSSTx's Avatar
You had to remove the master and the hard lines when you removed the engine and most likely still have trapped air in the system.
Old Feb 22, 2019 | 06:23 PM
Make sure all of your connections are correct and re-bleed starting from the RR, LR, RF then LF
