Can someone explain some metri-pack terminology?
Tanged vs. Tangless
150 vs 150.1 vs 150.2
pull-to-seat vs push-to-seat; what's the visual difference?
Any help would be appreciated. Also, if you have some blog, website, or thread that helped a lot with working with metri-pack, I'd appreciate that as well.
Thanks!
Thanks!
pull to seat would probably be where you crimp the terminal on, and then pass the wire/terminal through the front of the housing to install. Total **** up of a design really.
Push to seat would be normal where you insert from the rear and it can be released/refitted at any time. Pull to seat cannot as it's still attached to the loom so housing is impossible to remove.
Here's a very useful link I got from Ray_Mcvoy on 67-72chevytrucks.com.
https://ecat.aptiv.com/category?cat=Metri-Pack
It's a lot to wade through, but it helps make sense of this stuff.
