TAC Module Ground
Old Mar 19, 2019 | 01:08 PM
123pugsy's Avatar
Default TAC Module Ground
I fired up the 5.3 but throttle pedal (DBW) was unresponsive.
Does the TAC and throttle pedal use the sheet metal on the car as ground?
I have everything sitting on a wooden table with only the harnesses linking them together.
Old Mar 19, 2019 | 05:32 PM
ls1nova71's Avatar
No it doesn't use the firewall as a ground. Are you sure it has power? Is it the correct one for your engine/PCM?
Old Mar 19, 2019 | 06:21 PM
123pugsy's Avatar
It didn't have power to the pink the first time I tried it.. I hooked that up and still nothing.
Everything is from the same truck and I matched all the numbers online so pretty sure they match.
I will have to retrace the wires. I did a quick cut and wire nut hook up to test it.....just couldn't wait.
This is without the pink hooked up. I hooked it up after and same thing:
Old Mar 20, 2019 | 07:24 PM
123pugsy's Avatar
I hooked up a ground to the TAC and it's working now.
https://www.youtube.com/watch?v=cKDF...ature=youtu.be
