Fuel Pump Wiring Help
-The fuel pump works on direct power
-Multimeter shows power into the relay, but not out of the relay
-Relay configuration is not interchangeable due to a clip on the relay and harness
-Vats have been disabled in the PCM
-The Fuse and Relay appear to be in good condition
My next step would be to buy a switch and wire the fuel pump directly to the switch, but I'd rather not if I don't have to... Can someone with wiring knowledge point me in the right direction?
A current wiring "diagram" that was poorly made in paint is below.
