New to 5.3 swaps
Have you been to the LT1Swap.com web site? Lots of good stuff to read there. I can't answer your fuel tank or fuel pump question because my guess is that a Tahoe fuel tank won't fit a 1993 GMC 1500 truck. I used a fuel tank and pump from Tanks, Inc and a pump regulator from a Corvette.
I used a PSI engine harness for my 5.3 because my original 1999 Sierra truck harness was too damaged. It had fuses and relays built in.
You will likely need to adapt your transmission crossmember and shorten your drive shift to get your 4L60E to work.
What are you using for motor mounts? Will you have good driveline angles towards your differential?
Rick
