5.3 engine surge after engine swap
Old Apr 6, 2019 | 09:37 PM
Gater2001's Avatar
Default 5.3 engine surge after engine swap
I have a 2000 Chevy Silverado with a 5.3. The original motor spun a rod bearing so I replaced it with a 2009 5.3 used lingenfelter converter box and the intake,knock sensors and throttle body of the 2000. It surges when accelerating at about 35-60 mph. I have replaced throttle position sensor,mass air flow,and map sensor. I thought it was the map sensor cause if you unhook it and drive it don’t do it. Any help please.
Old Apr 8, 2019 | 09:44 AM
Alex41's Avatar
Check your fuel pressure and any possible, however small it could be, fuel leaks. I had the tiniest dribble of a leak on a swap once and I chased my *** on suspension vibrations till the cows came home.
