Rosta Cruise control switch
Old Apr 16, 2019 | 06:54 PM
Fasst450's Avatar
Default Rosta Cruise control switch
Im in full blown TMI mode. I have a 2002 5.3 with PSI harness and PCM going into a 72 El Camino. Also have the stock Silverado cruise module and a DBC throttle body. A few months ago when I was gathering parts, I read in a few places(including lsenginediy.com) that a Rosta 250-3020 cruise stalk will work for my swap. Im at the point where Im wiring the cruise control and now Im reading this switch will NOT work because it is a normally closed switch. I also read that this switch will work but the R/A function will not, which is fine with me. Has anyone used this switch and will it work? Or did I blow 40 bucks on a switch that I cant return now?
Old Apr 17, 2019 | 02:42 AM
Fasst450's Avatar
Disregard, I found an answer. For anyone in the future with this issue, heres a link to wire relays to make your Rosta stalk work
http://67-72chevytrucks.com/vboard/s...d.php?t=398006
