Hall effect sensor? - traction control
Old May 6, 2019 | 05:55 PM
corvettedave383's Avatar
Default Hall effect sensor? - traction control
whats the best hall effect sensor to pick speed of front wheel, to aid in my traction control system, holley dominator ecu etc
anyone? thanks
Old May 6, 2019 | 06:44 PM
pdxmotorhead's Avatar
OEM Anti lock sensor, you just add a extra one next to the factory one.. AS long as you had anti lock in the first place with a tone ring.
Old May 7, 2019 | 05:31 PM
thanks
Old May 7, 2019 | 05:58 PM
IIRC when I helped do this we used a factory sensor and a second mount,
we just welded a second bracket 90 degrees out from the first using a bit of steel.
