what is this?
Old Jun 1, 2019 | 01:49 AM
burrism's Avatar
Default what is this?
Good morning! So this is my first post in the forum, so forgive my ignorance. I recently obtained an LS3 engine and 6L80e tranny out of a 2017 Chevrolet SS for my 1959 Impala. I have the engine installed in the vehicle but as I am trying to get it running, I am running into connections and ports I am not familiar with. Specifically, the port located on the front passenger side pictured below. I bought a harness from PSI and had then reprogram my TCM and ECM but do not see a connector for this port. It appears to connect to the throttle body some how but is not used. (I am currently on travel so I do not have immediate access to the engine). As it appears to not be needed, how do I plug the ports where it is connected? what is it called?
Thank you.!
Old Jun 6, 2019 | 08:10 AM
TXjeepTJ's Avatar
EVAP solenoid, I use vacuum port caps. Can buy them at any autoparts store, comes with a variety of sizes
Old Jun 6, 2019 | 10:54 PM
burrism's Avatar
Thank you.
