6.0 swap hard to start when warm
Issue i am having is when at operating temp, the car is hard to start.
I have checked Fuel pressure when warm, and it is correct at 58 lbs, same as when cold. I have also used brake clean to check for vacuum leaks and none were apparent. Temp sensor is also in working order as i have a gauge readout Via the Torque app.
Once started, the car seems to run great, just will not start without a little throttle input from me when warm. It will crank and hit a few times but won't actually start. sometimes it will start but kinda stumbles up to a run. If I hit the throttle while cranking it still cranks a bit longer than normal but will fire up pretty well.
any suggestions on where to look next?
