Vehicle speed sensor wiring
and the standalone I am using has a newer style plug, theyre both two pin, but different styles. My question is, if i splice the right connector into my harness, are the sensors between the earlier style sensor and later sensor the same?
Don't want to somehow ruin something, cant find much info on it. Thanks!
Do all two plug vss work the same then? I.e the older style and a 3rd gen 2 plug vss?
There probably is a threshold voltage needed for the ecu to see it. I had to adjust the spacing between the reluctor and VSS to get enough signal. Doubt you'll have to do that on a GM unit.
2 wire is either stationary magnet reading a toothed reluctor or moving magnets with fixed sensor. The movement/magnetic field generates an electrical output that varies proportionally with speed. Sine wave output. The 3 wire set ups convert the sine wave to a square wave output.
