How to check harness causing P0134 code
Old Jul 4, 2019 | 05:01 PM
72farmer's Avatar
Default How to check harness causing P0134 code
I have a somewhere around a 04 5.3 DBW in my 71 C10. It has started missing like it is fixing to run out of gas when engine warms up. Since this is a 02 sensor causing code. How do i check the wiring at the 02 sensor to rule out the wiring before i waste my money on a new 02 sensor? Can i pull the connector and check wires with a VOM meter? Does it have a voltage going to it from ECM and what should it read?
Old Jul 4, 2019 | 09:02 PM
350SS's Avatar
you could always swap o2 sensors from left to right and see if the code follows. if it does, good chance its the sensor
