Building an LS7 for 01 SS
Old Jul 23, 2019 | 09:26 PM
HuddSS's Avatar
Default Building an LS7 for 01 SS
What can I use off my LS1 to my LS7? For instance. Can I use my LS1 coils? All my sensors and plugs. Injectors plugs. Cam positioning sensor, knock sensors. Map sensor. Basically want a clean swap and a good understanding. Is there a guide for this
Old Jul 24, 2019 | 08:19 AM
SE-R Spec's Avatar
Cam position sensor and knock sensors changed locations from the gen III motor to the gen IV motor, everything else should bolt right up
Old Jul 24, 2019 | 11:17 AM
HuddSS's Avatar
Looks like I’ll need a fabbed throttle cable bracket, and a cup washer for the crank spacing. Who makes these cable brackets? Anyone? Got my eye one injector harnesses and map sensor extension harness.
Old Dec 27, 2019 | 07:56 PM
REVINKEVIN963's Avatar
Hey. I am doing the same swap right now. I just got my MSD Atomic intake today and I need to buy a MAP sensor that will work with my 2001 computer. I have collected up on all of my wet sump conversion parts as well as my 1x timing set and 24x reluctor. The MSD instructions say to drill a hole and mount the MAP. So, I need to buy a new one. I am leaving my LS1 engine and transmission complete so I am not taking any parts off of original drive train. What MAP sensor did you use? Thanks.
