Can i swap a DBW ECM to a DBC to do some testing?
Old Sep 12, 2019 | 03:14 PM
72farmer's Avatar
Default Can i swap a DBW ECM to a DBC to do some testing?
I have a 02 5.3 Tahoe DBW engine in a old c10 truck. I am having "no activity" codes on the 02 sensors. It never goes into the "closed loop" because it is not reading either of the sensors. Any way i have done everything except change the ECM. It is a 411 ECM. I have another c10 with a 01 5.3 silverado DBC with the good tuned 411 ECM in it. I was going to swap the ECM's to see if that may be my problem. Then i got to thinking about the good DBW ECM into the DBC engine. Could i swap this ECM just to test and see if 02 sensors would respond? Or will it even start?
Old Sep 12, 2019 | 04:50 PM
You will have NO throttle opening. The TB will think the engine is off.
Old Sep 12, 2019 | 06:07 PM
72farmer's Avatar
It won't even idle? So it aint gonna work to test to see if it would go into "closed loop"?
Old Sep 12, 2019 | 06:14 PM
DBW TB's don't have an "idle circuit" or IAC valve like DBC ones do. The ECM cracks the throttle when the engine starts to idle, as far as I have heard.
Old Sep 12, 2019 | 08:51 PM
ls1nova71's Avatar
It should idle, but that's all it will do. At rest a DBW throttle body isn't fully closed.
Old Sep 13, 2019 | 12:34 AM
Thank you! I wasn't totally sure of that. Sorry OP!
