Plug wire header clearance
Old Sep 28, 2019 | 09:33 AM
Mikes64's Avatar
Default Plug wire header clearance
Looking for a set of plug wires that will clear my headers (Speed Engineering Shortys) #3 hits hard with original wires, 2 & 4 just touch. I purchased a set of aftermarket wires and high “high heat boots” and a couple just touch, not sure this is acceptable. Any options out there?
Old Sep 28, 2019 | 12:23 PM
bobcratch's Avatar
msd super conductor multi angle is what i'm using with block huggers https://www.summitracing.com/parts/msd-32819/overview/ (note, there are two different part numbers, one is "ls truck" and the other is "ls1". I think the only difference is that the truck set is longer.)
the spark plug boot is firm but flexible, and you rotate/bend them to any angle you need to clear the headers. Then just put insulator over it and you're done.
Old Sep 28, 2019 | 01:37 PM
LLLosingit's Avatar
My son in-law bought this set because they were cheap but still a decent wire. Taylor Street Thunder Spark Plug Wire Sets 51046 $29.99
Old Sep 29, 2019 | 07:37 AM
Mikes64's Avatar
I see where they can be bent to clear the headers, may be what I need. Thanks for the link.
