Holley mounts and low mount AC ?
Old Oct 4, 2019 | 07:11 AM
Houston_t's Avatar
Default Holley mounts and low mount AC ?
Hey i have searched and have not found an answer to this and was wondering if anyone here would know.
Im looking at possibly using the Holley LS mount system in my 87 Grand National. My setup is a 6.0 with a LSA supercharger and i plan on using the GM modified FEAD and notching the frame for the factory low mount AC compressor. Will the Holley mounts interfere in that area ?
Old Oct 4, 2019 | 07:46 AM
user 4737373's Avatar
The Hooker Blackheart G-body LS swap engine mounting brackets will only provide compatibility with the Holley low mount A/C compressor set-up when it is installed at the F-body or truck offsets. The compressor will experience interference with the right side engine mounting bracket if an attempt is made to install the Holley compressor set-up at the Corvette FEAD offset.
Old Oct 4, 2019 | 08:49 AM
Houston_t's Avatar
Ok, thanks for the quick reply.
