Harness and engine Identification questions
Old Oct 10, 2019 | 04:45 PM
V8e36's Avatar
Default Harness and engine Identification questions
I'm new here , I apologize if this was asked already . Looking to get pointed to the right direction . In short I'm swapping a 5.3 into my e36 bmw. I have the engine has truck intake and drive by wire throttle, unsure the year . I know I will be going with a car intake for clearances . Question is can I 1. Use any harness/pcm from any year or do I need to have one specific to this engine? If I decide to stay drive by wire is the gas pedal the only addition I need to harness and pcm ?
Old Oct 10, 2019 | 05:08 PM
LS BRAVADA's Avatar
Get everything from one donor vehicle. When you start piecing things together your in for more troubles
Old Oct 11, 2019 | 08:01 AM
1964SS's Avatar
For easiest install you will want to match the year or at least use the pcm/harness from the same gen family.
Old Oct 11, 2019 | 09:28 AM
psiconversion's Avatar
LS1Tech Sponsor
If you need help deciding what harness you would need, our team would be more than happy to help you. You can check out what we have here, https://www.psiconversion.com/produc...ing-harnesses/ or if you have further questions give us a call 732-444-3277 ext. 2
__________________
Your Source for LSX Conversion Parts!
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
