Pontiac 400 to LS
Old Oct 12, 2019 | 06:43 AM
VandykeT/A's Avatar
Default Pontiac 400 to LS
I’m LS swapping my 80 Trans Am. Right now it has a Pontiac 400 in it. I’ve searched and searched for answers on what I need for the motor mounts. I know they’re several brackets that bolt to the LS and hook to stock mounts but they’re all on Camaro’s since I’m going from the boat anchor Poncho will I need to move the stock motor mounts to SBC location in order for this to work.
Old Oct 12, 2019 | 10:01 AM
Once stripped to frame Camaros and Firebirds are the same animal. Use SBC frame stands and you're good.
Old Oct 12, 2019 | 07:52 PM
LS BRAVADA's Avatar
Although BOP&C trans won't mount to LS engine
Old Oct 12, 2019 | 09:12 PM
VandykeT/A's Avatar
Will the frame have to be drilled or can I use the pontiacs original mounts/holes. And the bellhousing has been replaced with a LS bolt on style. Is it something on the converter that won’t let it work?
