Need some help with an injector problem in my swap
Hard to say without seeing the car how you have it wired. I ground everything, like double and triple grounds with 00 Cable
but a .1v drop to the injector aint bad.
what kind ohm drop do you get on the injector control circuit (from the injector to the ecm) ? affix your probes to each and and wiggle the harness and see of you lose continuity.
how's it run with a jump box connected?
So I checked the voltages on the pins in the picture. I have the values written along side of them. Not sure what pin#3 for the injectors should be? Pin#15 on the red connector, for the generator turn on signal seemed low too. I couldn't find what these values should be.
