A/c in motor swap
My Cold Case radiator has two fans and I have two of these Four Seasons fan controller kits. One for each fan. Each fan has its own power, ground, relay, adjustable temperature control and temperature sensor for complete safety and cooling reliability.
Rick
Rick
The GM 5.3 AC compressor in the ventilation system will be operating similar to how the Ford AC compressor clutch operated. However, you need to connect the compressor clutch activation wire to the green wire on the Four Seasons fan controller kit as a "T'eed" off connection. This allows the activation of the e-fans as soon as your AC compressor is commanded on. You cannot wait for the electric fans to come on as the engine temperature climbs unless you want to damage your compressor due to excessive head pressures.
Rick
