Power Steering pump question on Lq4
Old Nov 10, 2019 | 09:48 PM
yeti0810's Avatar
Default Power Steering pump question on Lq4
I'm currently running a Saginaw type 2 power steering pump, or a basic F-Body power steering pump. I changed the pully to a Turn One F-Body pulley a while ago. I'm currently running a power steering cooler also ( literally put t on last month). I am still loosing power steering when stopped. Additionally, my fluid has been overheating like crazy before putting on the cooler. Pretty sure my pump is toast as it's starting to make a knocking noise.... but I want to make sure I set it up correctly when I change it out.
I've been reading about different diameter pulleys. Mine is currently 6 1/2. Is there one bigger to maybe slow down revolutions?
For reference, I currently have a 6.0 with an ls1 accessory set up in an 82 Camaro. Thanks in advance for any help!
Old Nov 11, 2019 | 12:51 PM
steering_experts1's Avatar
If you want to give us a call and talk with our tech department, we can discuss your issue and help resolve it for you.
Thanks,
Junior
Turn One Inc.
