Looking for ls trans bolt pattern dimensions
Old Jan 13, 2020 | 01:53 PM
ricardo.benin's Avatar
Default Looking for ls trans bolt pattern dimensions
As the title states I’m looking for an ls bolt pattern dimensions for an adapter plate I am making. Looking for dimensions of the oil pan bolt holes.
Old Jan 13, 2020 | 02:12 PM
The title does not make sense. "Trans bolt battery dimensions"??
Old Jan 13, 2020 | 02:52 PM
[QUOTE=G Atsma;20195377]The title does not make sense. "Trans bolt battery dimensions"??[/QUOTE
my phone autocorrected from pattern to battery.
Old Jan 13, 2020 | 03:03 PM
LOL I hate when that happens!
Having said that, the bellhousing bolt pattern is the classic big/small block Chevy pattern used since 1955.
Old Jan 13, 2020 | 06:02 PM
Thanks, but the issue I have is finding the dimensions with the two bolts that go in the oil pan. I’m running a dual clutch bmw transmission and having the worst time getting this correct.
Old Jan 14, 2020 | 10:22 AM
truckdoug's Avatar
look in the tools & fabrication section. there is a thread with info to reach out to folks that have .dxf files for all sorts of LS-related bolt patterns.
i recently lost a buncha files I didnt backup or i'd have a copy for you
Old Jan 16, 2020 | 04:26 PM
txcarbuilder's Avatar
Here are the dimensions I use. From the crank centerline down 6.790 inches and left and right 4.326 inches
