Cut and extend OBD-II port?
Old Jan 16, 2020 | 02:07 PM
Murray's Avatar
Default Cut and extend OBD-II port?
(2008 5.3 Vortec Gen IV)
I had the stock wiring harness sent away and rebuilt/thinned. Today I mounted the ECU and the small fuse box on the inner drivers fender which was pretty well my only option. It's looking like the OBDII port and the gas pedal plug wires are not going to be long enough to reach. Can I cut and extend my OBDII plug? I'm thinking splice in pieces so it would be two solder joints per strand. I thought I read somewhere you couldn't splice them? If it's doable do I need to use the same wire gauge?
Old Jan 16, 2020 | 07:16 PM
one4torque's Avatar
Default Obd plug
I extended mine 5’ from engine bay to the stock location under the dash. Works fine.
Old Jan 16, 2020 | 07:45 PM
I think as long as quality wire is used with good solid connections, it should not be an issue. You're only going a few extra feet, if that.
Old Jan 16, 2020 | 08:09 PM
Murray's Avatar
Default .
Alright I'll plug in my soldering gun!
Old Jan 16, 2020 | 08:54 PM
67Skylark's Avatar
No reason you can't, you can also just purchase and extension cable, search amazon $10 bucks will get you five foot cable.
Old Jan 17, 2020 | 08:41 AM
LS_then_Ideal's Avatar
FYI, we extend these cables, for the work, I do 20-50 feet. Best to use either shielded 1 pair cable and ground the shield on one end only or twist the wires. This will help with electronic noise related issues (only an issue if you are running software while driving or using the connection for gauges)
Old Jan 17, 2020 | 10:19 AM
bobcratch's Avatar
anything that's a twisted pair, extend with a twisted pair. I recommend at least 1 twist per inch.
