Fuel pump cleaning
Old Feb 3, 2020 | 11:30 PM
33willys's Avatar
Default Fuel pump cleaning
My car has been laid up for the past 3 months while I put a 'Vette rear end under it. Soon it will be time to fire it up again but I'm worries about the in-tank pump may be gummed up and fry when it gets initial power. Is there any way to clean a pump? Soak it in fresh gas for several days? Shoot brake cleaner into it? inputs anyone?
Old Feb 4, 2020 | 12:47 AM
ls1nova71's Avatar
I store my cars over the winter and have never had a problem starting them later. I wouldn't worry about it if it if I were you.
Old Feb 4, 2020 | 06:55 AM
Michael Yount's Avatar
Mine sat for a year while I was swapping in the LS3. I simply pumped most of the fuel in the tank out (about 6 gallons) - and put in 5 fresh before starting the first time. No problems at all with the fuel pump. And I split the 6 gallons of year old I removed into 3 apiece into our daily drivers added when they were about 1/2 full. Couldn't tell any difference at all.
Old Feb 4, 2020 | 12:04 PM
I noticed OP is in New Mexico, so winterizing is not a concern.
I agree with you guys. Run some fresh gas thru the system and all should be well.
Old Feb 4, 2020 | 12:41 PM
AwesomeAuto's Avatar
You'll need to get closer to 3 years before gasoline gives you this problem.
