Speedo out from E38?
Old Feb 4, 2020 | 09:32 PM
rubrhammer's Avatar
Default Speedo out from E38?
If I change from 4 wheel sensor to serial data in an E38, will it activate a pin and if so which one? I'm using HPTuners. I can't seem to get on their forum to ask there. The E67 has one.
Old Feb 5, 2020 | 03:10 AM
LS BRAVADA's Avatar
Here's what I found:
both 71-72 on X1 is output speed sensor (M10) option
71) yellow wire, circuit 400, output speed sensor high signal
72) purple wire, circuit 401, output speed sensor low signal
mignt need to turn on M10 option
might also need CPP, reverse lockout, backup switch signal and skip shift disabled or added
