Need help...Converter spacing problems
Old Feb 5, 2020 | 10:29 PM
Foxkiller's Avatar
Default Need help...Converter spacing problems
I am trying to do a ls3 to a 400 transmission conversion. However when I installed the ptc converter I only end up with .150 spacing between the converter and the flywheel. All the articles I have read say I need a minimum on .250. I am using a prw dished flexplate with the adapter sleeve. What am I doing wrong. It is way to tight for my liking and I'm afraid I will wreck my pump upon start up.
Old Feb 6, 2020 | 11:59 AM
Haggar's Avatar
I would check with PTC, but 0.150 sounds like it's right in the normal range to me.
Old Feb 6, 2020 | 12:13 PM
98CayenneT/A's Avatar
Don't know where you're getting your info but .250" would be WAY to much.
At .150" you are good but that's what I would consider max.
Old Feb 6, 2020 | 01:36 PM
Foxkiller's Avatar
Correction on the amount of clearance I have. I failed at fraction conversion. I have 1/16 of inch of clearance and need 1/8 of clearance. I've called PTC and PRW. Both say i should have at least 1/8 or more clearance with the parts I have.
